An e-way bill or electronic-way bill is a document introduced under the GST regime that needs to be generated before transporting or shipping goods worth more than INR 50,000 within state or inter-state. The physical copy of e-way bill must be present with the transporter or the person in charge of the conveyance and should include information such as goods, recipient, consignor and transporter. The e-way bill was rolled out nationwide on 1st April 2018.
Under GST, the process and procedural aspects for the movement of goods are prescribed in the e-way bill rules. E-way bill stands for Electronic Way Bill. It is usually a unique bill number generated for the specific consignment involving the movement of goods. However, it is to be noted that the e-way bill implementation was deferred when GST came into being on the 1st of July, in order to give more time to the government, businesses and transporters to prepare for its full and final implementation. States like Gujarat continued to have Form 402 in GST, and clear rules were laid down as to how to help businesses fill a GST Form 402 online till the implementation of the GST e-way bill is complete.
It is applicable for any consignment value exceeding INR 50,000. Even in case of inward supply of goods from unregistered person, E-Way Bill is applicable.
The E-Way Bill needs to be generated before the commencement of movement of goods.
The validity period will be counted from the time of generation of the E-Way Bill. The validity period of the E-Way Bill may be extended by the commissioner for certain categories of goods, as specified in the notification issued in this regard.
Form GST EWB-01 is an E-Way Bill form. It contains Part A, where the details of the goods are furnished, and Part B contains vehicle number.
Yes, either a registered person or a transporter can generate an E-Way Bill although it may not be mandatory.
The transporter should generate a consolidated E-Way Bill in the Form GST EWB 02 and separately indicate the serial number of E-Way Bill for each of the consignment.
Upon generation of the E-Way Bill, on the common portal, a unique E-Way Bill number called ‘EBN’ will be made available to the supplier, the recipient and the transporter.
Before transferring the goods to another vehicle and making any further movement of such goods, the transporter needs to update the details of conveyance in the E-Way Bill on the common portal in Form GST EWB 01.
Note: If goods are transported for a distance of less than ten kilometres within the State or Union territory from the place of business of the transporter finally to the place of business of the consignee, updating the details of conveyance in the E-Way Bill is not mandatory.
The transporter has to generate the E-Way Bill in Form GST EWB 01 on the basis of the invoice, bill of supply or the delivery challan.
The E-Way Bill can be cancelled electronically on the common portal within 24 hours of its generation. The E-Way Bill cannot be cancelled if it has been verified by an officer during transit.
Yes, the details of the E-Way Bill will be made available for the recipient of goods only if he is registered. The recipient of goods should communicate acceptance or rejection of the consignment covered by the E-Way Bill within 72 hours of the details being made available.
If the recipient of goods doesn’t communicate acceptance or rejection within 72 hours, it will be deemed as accepted by the recipient.
The facility of generation and cancellation of E-Way Bill will be made available through SMS.
If there is any incorrect information or a mistake in the e-way bill, then it cannot be corrected or edited. In case of any errors in the e-way bill, the only option is to cancel the e-way bill and generate a new e-way bill with correct details.
The validity of the e-way bill can be extended under circumstance of exceptional nature, law and order issue, trans-shipment delay, accident of conveyance etc by updating the reason for extension and the details in Part B of Form GST EWB-01.
The transporter or the person in charge of a conveyance should carry the following documents:
At the place of verification, the officer may intercept any vehicle to verify the E-Way Bill or the E-Way Bill number in physical form for all interstate and intrastate movement of goods. On the ground of suspicion of tax evasion, a physical verification of the vehicle can be carried out by an officer after obtaining necessary approval from the commissioner or an officer authorized on his behalf. If the physical verification of vehicle is done at one place –within the state or in any other state, no further physical verification will be carried out again during the transit, unless specific information of tax evasion is made available subsequently.
After every inspection, the officer needs to record the details of the inspection of goods in Part A of Form GST EWB 03 within 24 hrs of inspection and the final report must be recorded in Part B of Form GST EWB 03 within 3 days of inspection. If the vehicle is detained for more than 30 minutes, the transporter has an option to complain by uploading the details in Form GST EWB 04.
There will be no change in the process of generating e-way bills.
A user can use the following steps:
Businesses with cumulative annual turnover of Rs 10 crore and above need to generate e-invoicing for B2B transactions.
e-Way bill needs to be generated if the consignment value is above the e-way bill threshold. If your business is under the purview of e-invoicing, both need to be generated. The interesting part is that when invoice details are shared for generating e-invoices , the e-invoice portal automatically shares the details with the e-way bill portal as well. This ensures e-way bill is auto-generated. If you are using a connected solution, you can generate both together without the need to do it manually.
The E-Way Bill format in GST comprises of 2 parts – Part A and Part B.
The Part A of E-Way Bill in Form EWB 01 aims to collect the details of consignment, usually the invoice details. Accordingly, the following details need to be captured.
In Part B of Form EWB 01, the vehicle number in which goods are transported needs to be mentioned. This will be filed by the transporter in the common portal.
Warehouse Inventory Management – A Complete Guide
Multi-Location Inventory Management – A Definitive Guide
Saved Report Views: Enhancing Efficiency and Delight in TallyPrime Reports
Simplifying e-Commerce Sales Details in GSTR-1 with TallyPrime 4.1
Streamlining Compliance and Payments to MSMEs with TallyPrime 4.1
TallyPrime’s Enhanced Payment Tracking Solution for MSMEs
